1965 289 Mustang starter is stuck and won’t come off
1.6K views 18 replies 8 participants last post by  MidnightExpress
Help please. I have removed both bolts and wiring. The starter will not budge at all. What the heck is going on?
^^This. Its possible the gear is seized and stuck in the teeth of the flywheel(working under the assumption here that you are replacing the starter because it failed). Also sometimes aluminum corrosion will sometimes bond with a seperate mating surface(It seems the aluminum wheels will often attach themselves quite securely to the steel wheel hub in my daily driver...to the point that I have started applying a thin film of oil between the 2 to prevent this). Either way a hammer works....any old sledge is fine if you dont plan on re-using the starter...deadblow if you do.
Hit the round case, not the ears or nose because that's where the money is for a core / rebuild. The case can handle harder hits
