HI All, I finally purchased my first Mustang, a 65 Convertible with Drum/Drum and 200ci. When I bought her, the owner told be about the brakes that needed a complete overhaul, and the price was adjusted accordingly. I wanted to do the brake work myself.
I have replaced the brake booster, master cylinder and put new drums and shoes all around. I bench bled the master, and bled the brakes on the car many times, but can't get any real pressure in the system to stop the car or the drums.
I'm concerned that the brakes have been 'looked' at many times, and therefore something is goofy (my evidence is some did a hack job on the previous booster/master cylinder job around the firewall. I have fixed this with a Scott Drake replacement.
Here is my thinking so far
1. Master cylinder is bench bled and there are no bubbles coming when loaded on car. (assume Master and Booster are OK)
2. I get hydraulic fluid to all 4 corners with no bubbles (assuming lines are okay)
3. I can make the wheel cylinders pop off (i.e. pistons come out) Therefore I'm assuming they are ok.
I'm kinda left with the brake shoe assemble or I have 10in drums on a 9" car.
I can't see a definitive picture in the shop manual of a 9" drum assembly, but I have seen some pictures with a adjuster/lever cable going from the bottom spring to the top. See the before/after pictures and my car does not have those. Also in my pictures, the bottom spring interferes with the adjuster wheel - therefore other evidence of missing pieces.
I also note that there are no 'pegs' that go from the wheel cylinder to the brake shoes - I can't determine whether they are supposed to be in there (available room seems tight). I have seen on some videos that they occur, but not sure if those are on V8 10inch drums.
Any help appreciated - I've been at this for 4 days now and my wife is about to divorce me!!
Phil.
Phil.
