My Haynes manual shows a cam spacer that fits over the cam end (inside of the thrust plate). This was missing on my 289; is one necessary?
Thanks,
Marc
Thanks,
Marc
Was your engine running fine without it?My Haynes manual shows a cam spacer that fits over the cam end (inside of the thrust plate). This was missing on my 289; is one necessary?
Thanks,
Marc
The retaining plate was completely different. IIRC, machine work would be necessary to do that, since the bolt holes were relocated to prevent mixing the parts.22GT, question about this, just for trivia for myself.
If you have an older block that came with the spacer, and you replace everything, cam gear, retaining plate and screws, will that work??
