I pulled the motor the other day and have had a few days now to to get into it. Removed the valve covers, intake manifold, fuel and water pumps, distributor etc. The water pump was clean in one port and some rust in the other side. Same for the intake, the 4 corners had rust but not as bad as I've seen in some videos. My concern though is I did find some sludge below the valve covers and intake. Can I just clean this and move on with new gaskets etc? I've read some cleaners are more harmful and should be avoided for sludge removal. The motor has only 57k miles on it, everything spins pretty easy from the harmonic balancer. Also, should I remove the timing chain cover and check for slop as well as add a new gasket? Can I do some type of compression test to see if the totals are all in the same range or do you need to have the car running to do this? I have some experience working on cars but this is my first one that really requires a lot of work with the engine. I'll post my pics after I download them. Appreciate any advice offered. Thanks.
