One idea that hasn't been mentioned yet, front wheel bearings. A few years ago I had a vibration that I chased down. It ended up being a galled bearing race in an outer front wheel bearing. I assume it was a metallurgical issue or flaw with the rollers themselves as the other front bearing races (all Timkin) were fine. Note my diagnosis included, tires, friction modifier for the rear end, u joints, drive shaft balance, and yoke wear. I was about to pull the axle shafts and pumpkin when I spun the front wheel and felt the flaw. Pressed out the damaged race, pressed in a new one, packed the bearings and all was well.
I should note that when you go to the local parts house often enough, they get to know you. In this instance, it was a Sunday and they were short handed at the counter so my counter guy pointed in the direction of the back room and said, the press is in there, go ahead and press the new one on yourself!!!
