Heidts suspension
24K views 18 replies 16 participants last post by  LSG
i'm kinda thinking on this set-up, there running a special for free ps/bigger sway bar i think for 2300. does anyone have this set-up, and if you do how do you like it ?? i'm going 351W in the 65 vert and thought this would be the way to go possibly! or should i just save the money and mod the towers....thanks, Jim
This is the NEW custom IFS weld in suspension package for 65 - 70 Mustangs and 67-68 Cougars from Total Cost Involved Engineering (TCI) offered by Stang-Aholics, LLC. This TCI Suspension system will open up the engine compartment for header clearance and will help with more clearance for big block and small block engines. This is not a Mustang II type front suspension system. It uses shims to align the upper A-Arms instead of a slotted adjustment that the Mustang II kits have. So, your front suspension can never slip out of alignment! Along with opening up the engine compartment, this kit will allow you to lower your Mustang about 2 Inches in the front with the included adjustable coil-over shocks. The forward mounted rack and pinon will allow for better long and short tube header clearances over a rear mount rack and pinion. This kit will also help to eliminate the bump steer issues that plague the classic Mustang steering so your Mustang will finally track straight over the bumps in the road The late model power or manual rack and pinion system will allow you to enjoy precise steering with alot less effort. The 11" Vented Disc brake kit will greatly improve your car's stopping ability enabling you to stop on a dime! Overall this kit will fix many of the design flaws that the classic Mustang steering and suspension suffers from and allow you to drive and enjoy your classic Mustang like never before.
CURRENT SPECIAL: SAVE WITH OUR BUY IT NOW PRICE OF $2263!! (Regular Price is: $2515) WE ARE ALSO CURRENTLY OFFERING A FREE FRONT SWAY BAR, FREE POWER RACK AND PINION UPGRADE, FREE SMALL BLOCK ADJUSTABLE ENGINE MOUNTS AND FREE SHIPPING!! YOU WILL SAVE AN UNBELIEVABLE TOTAL OF $800 WITH THIS SPECIAL OFFER!!
ALSO, IF YOU PURCHASE THE TCI TORQUE ARM REAR COIL OVER SUSPENSION KIT (SEE OUR OTHER AUCTIONS) PICTURED BELOW, WE WILL SHIP BOTH SUSPENSION KITS TO YOU NO CHARGE!! HOW'S THAT FOR AN ECONOMIC STIMULUS PACKAGE FOR MUSTANG ENTHUSIASTS? YOU WILL HAVE MORE CASH IN YOUR POCKET TO GET SOME OF THE OTHER PARTS YOU NEED TO FINISH YOUR 'STANG!
The kit includes the following components:
Frame Reforcement Plate Kit
Flattened Shock Mounting Towers
Custom TCI Dropped IFS Spindles
Steel Inner Fender Panel Kit
Jig Welded Crossmember
TCI Coil-Over Shocks with Adjustable Spring Tension
Black Powder Coated Springs
Urethane Bushed Tubular Upper and Lower A-Arms
11" Disc Brakes With OEM GM Calipers
Power or Manual Rack and Pinion Steering
Steering Tie Rod Ends and Extensions
FREE SWAY BAR KIT!
FREE SMALL BLOCK ADJUSTABLE ENGINE MOUNTS!
Full Detailed Instruction Manual With Pictures and Descriptions at every step.
Disc brakes, power rack and pinion, coil overs and better steering geometry. It's hard to beat for the money. Some power rack pinion systems alone cost that much. I would confirm track width and wheel offset to make sure it works with the wheels you are running.
If you do it, you are required to perform an extensive write up on VMF.
Black_67Stang said:
I was under the impression that you did not need to mod the towers with a 351?
It's not a requirement to fit a 351W in there, but the space does get pretty tight around the shock towers.
If the main reason for wanting that kit is for the 351 engine swap, then IMO it's not worth the amount of money and work that kind of kit requires to install, but there are other reasons for using the kit so it's really up to you.
I've stated several times in previous threads that I just don't see the sense of spending $2k+ to replace a 50 year old suspension design with a 40 year old design, especially when the older design has actually been proven superior in handling capability with only simple mods but again that's only my opinion. Just don't be fooled by advertising propaganda into believing it isn't really a MII suspension, because it is. It may be modified some compared to a stock MII set up, but it's still an MII suspension.
#5 · (Edited)
The kit you're looking at isn't a Heidts kit; it's a TCI. I don't know anything about their quality or service (though Heidts leaves a lot be be desired).
ozarks06 said:
The kit you're looking at isn't a Heidts kit; it's a TCI. I don't know anything about their quality or service.
I have the Heidts kit with the old-style springs and shocks. It is a nice kit and the quality is good. Customer service is excellent. I would NOT do the swap unless you really need the space for a mod motor or a big block. You should be able to do a 351W swap without it. It is a lot of work and requires tweaking a lot of other things, like re-routing your brake lines (and probably changing out your master cylinder), add in $200 for a steering column shaft or $500 for an Ididit column, finishing out the panels that cover the shock towers, etc. On top of that, a SBF looks pretty tiny in the engine bay that now has all that extra room - it looks almost lost in there.
It is a good buy to get R&P, discs, coil-overs, since those add up to a lot more money if you do them to the original suspension.
If you want a Heidts kit I would check with Tim's Hot Rods in Washington (state), ibuildm on ebay. I got my kit from him and it was about 20% or 25% less than list price, no shipping cost, and to my door in about a week. It was the best price I could find by far.
I have the same set up for my wife's car. Originally a V-8 with no options. Now with the Heidt's Kit: Quick Ratio Rack PS, Power Disc brakes, HD sway bar, new upper and lower control arms and lots of engine bay room for 351W. No regrets.
+1 I got my heidts kit from ibuildm as well...cost something like $1700 or so, though I didnt opt for coil over shocks(didnt see the point) however that TCI kit does have a better setup for the UCA mounting point...ibuildm sells that kit as well...if you are worried about one of the other MII kits slipping out of alignment, there are mods you can do to prevent it happening(a couple I can think of off the top of my head) but that is still a MII kit...just like Heidts updated superide II kit as a matter of fact
i know i can drop a 351 W in the car but its really tight! i was just thinking on a new suspension for the car and have some fun....i kinda like the idea of haveing plenty of room under the hood! and was also thinking of the rear set-up also...i don't know, mybe i'll just go roller arms etc and call it good, its not a daily driver...its a weekender!
I'm eagerly planning the same fate for my car, the 351W and suspension package. When I got started the front frame rails, cowl, and firewall were so rotten the whole front end had to go, so why not mod the suspension for a better ride and extra room while I'm at it? Anyway, I did have some questions regarding power steering conversions associated with a 351W engine swap and a Heidt's or equivalent TCI kit. I'll be crossing that bridge soon and thought I'd ask around, see if anyone can give me some advice to save some time.
With these kits, width of the engine bay is no problem for the 351. What you have to watch for is height. The distance between the hood and crossmember is just barely enough to get a 351 under the hood. You need a double sump oil pan and clearance is very tight. Just do a search here and you'll see much discussion on it.
Doug
For those with rotted frame rails and inner fenders, etc. you might want to look into the Fatman Fabrications Performance Suspension Module (PSM). I saw it at a show and it is a complete replacement front clip from the firewall forward that uses '94 and up Mustang spindles, brakes, and struts, power rack, sway bar, etc. and has plenty of room for any engine. It even has provisions for the bolt on sheetmetal (fenders, etc.) to bolt right on...
Just a thought to throw out there for people like JDAsher...
I know this is an OLD thread, but did you happen to get this kit? I'm shopping for front/rear suspension and power steering conversion kits at the moment and would love to hear how it went!
How does that effect the unibody strength? deleting the shock towers means also deleting the shock tower to firewall suppoet leaving only a monte carlo bar. I thought about that for a while I have a Maler bar that is a one piece design bolting at the firewall and shock towers with an integral bar that spans accross connecting the shock towers. How do the MII kits compare to the newly designed coil overs kits that use the shock towers? I think Fatman offers something like that as well. I'm curious to hear opinions/actualy experience about the 2 because im still not sure exactly which way to go.
