Hello,
I have a 66 289 w/o AC & I would like to add a shroud for summer.
Couple question:
1) The width of my radiator is 18". The radiator looks new so I wanted to make sure that this sounds like the stock size for this car.
2) The NPD catalog has a few options for my application:
- 260, 289, 20" reproduction 8146-1A $32.50
- Concourse correct repro w/ proper cut-outs and rubber shield as original $32.00
- 6 & 8cyl 3 1/2" deep $79.50
*I measured and I think the 3 1/2" may be too deep. I have read that the fan should be sticking out a bit and I think the 3.5 will bury it a bit. So should I go with the Concourse and the standard 66 289 bracket kit?
3) What is the correct installation procedure?
Is the shroud one piece or does it split to install? What if anything needs to be removed when installing.
Thanks,
_Seth
Couple question:
Thanks,
_Seth
