I've heard this term for many treads. Just exactly what does it take to create a "Over Boost". What is over boost?
Folks want a larger pulley to stop this over boost. How do you determine the pulley size to stop the over boost?
Only information I can help with is the HiPo cars, Cobra Jets used a larger pulley to not over rev the pump, destroying the cam pack in the pump. The larger pulley slowed down the RPM on the pump . Had nothing to do with "over Boost".
If a sawing, twitchy steering, it is a loose, worn PS issue, not a pressure problem.
