I will try my best to keep this respectable, and it is not intended as a bash fest, but rather to caution others on my experience with SSBC brake kits. After researching (apparently not well enough), I chose two SSBC bolt on kits - the W110-11(rear) and W120-13(front) kits.
As an overriding statement(again from my personal experience) I can say that SSBC's quality control is poor, and their customer service is next to non-existent and not at all helpful.
With regards to the W110-11 kit - the hub diameter of the rotors provided does not match up to the axle hub. They provide a so called adapter that matches neither the diameter of their own rotor, nor the diameter of the axle hub. In addition to this, the lug holes drilled in the rotor are drilled to 9/16 for a 1/2 stud??? The brake pads themselves are very poor quality and i replaced immediately with EBC pads. As for getting your e-brake cables to fit - forget about it. After researching quite a bit, I have found that this was a known problem by SSBC for many many years and still not corrected. How helpful was SSBC customer service for my issues with the W110-11 kit? - not at all, and most times didn't even bother to respond!
Now, for the W120-13 kit. After installation, the rotors showed a 21 thousandths runout - you could visibly see the wobble in the rotors. After contacting the so called SSBC customer service, indicating to them that is seemed like it was a problem with the hubs, and after a long time waiting i was sent a new rotor(without hub) to try. Took everything apart, installed the new rotor to their hub, and same thing. As it turned out both of the hubs that were provided with the kit were machined incorrectly with the inside rotor mounting face being off 11 thousandth from one side to the other. Sent this to SSBC "customer service", and guess what - SSBC has not even responded to my phone calls or e-mails. If this were not enough to consider, the "quality kit" provides low quality installation parts - the bearings and pads provided are very cheap/low quality and I replaced them immediately. So, in conclusion for this kit, in addition to the money spent on this so called "quality" kit, I had to spend another 300 at the machine shop to even make it work - and SSBC doesn't seem to care.
If I had it to do over now, I would take the advice of helpful and knowledgeable people like Shaun and Opentracker on my selection of brake kits. I will never do business with SSBC again.
Again, this is my experience with these particular kits. Do your research before you buy - and as I have learned doing this restoration - I cannot say enough for the importance of Quality Customer Service!
