+1. Your timing light check in your driveway
must be with vac disconnected, or else it will affect your total base+mech timing that you're trying to read for WOT effect. There is no load in your driveway, and vac will be high. Once total is set with the light at perhaps 36° to begin testing, I would start testing by connecting to ported vac with this setup, as the curve is designed for that, along with the greater initial advance. The way to set initial is to set it at 3500 (or whatever you find to be all-in) for 36° total, and it will settle to whatever is left for idle. Easy and uncomplicated.
With ported vac, you should see about ±12° initial + 24° by 3500 = 36° total, while part-throttle cruise at 2000 should have 24 + 10 vac = 34°. That's really light, and IMO the curve should be all-in much earlier, so cruise is much higher in the mid-40s. That's more of a truck/tow curve, and odd he did that — if you have the numbers right.
I am not suggesting to use manifold vac yet, but the numbers would change to 22 idle, and the same as ported for 2k and 3500. The only change is at idle. So, 12 initial + 10 manifold vac = 22° at idle. That may be fine, but is not what he set you up for, and you need to baseline with what he gave you and how you should first run it.
I'm a manifold-vac guy, but the distributor must be set-up properly for that. Just moving from ported to manifold vac will not be correct curve, and needs to include testing for peak efficiency idle timing and other factors for a re-curve. No big deal, but you can't just swap nipples and say it's great or it sucks. Not a fair, reasonable, or beneficial comparison.
