I have a 4 speed and 3.25 8" rear end in my convertible. 289, headers, EBrock 600 cfm, single plane EBrock torquer manifold. I am looking to decrease highway rpms a bit and also upgrade the rear end to some form of limited slip.
Right now the toploader has very close ratios (I do not know the numbers) between 1st, 2nd and 3rd. Pretty big jump to 4th which I assume is the 1.0 ratio. The other three gears are higher (and closer) than I would like.
Here are my basic requirements:
So I am considering doing the following:
- Would like to keep the top loader in operation in case I go for lots of HP down the road. I like its shift feel and also the confidence it gives me knowing that it is built like a tank. I don't think I am going to break it.
- I do a reasonable amount of highway speed cruising. Right now the RPM's are higher than they need to be in 4th. Slower spinning crank if nothing else would make me more comfy.
- 1st gear is at the limit of being too high. I am ok keeping it the same but would not want to go higher.
- I have no need to optimize 1/4 mile times. Heck I can't take the car to the track without a roll bar and I am not about to put a roll bar in it. I like keeping it pretty near stock in appearance and carry kids in the back somewhat often.
- I think my 8" is fine for the motor the way it is, I have 205 width tires on it. They don't put much stress on the drive line before they break free.
- swap out 1, 2 and 3 for whatever the widest gear set available would be.
- go from the 3.25 in the rear back to the car's original 2.80 gearing to take 4th gear up a bit higher hoping that the wider gear set will leave 1st in the same place. Add Posi while doing that swap.
