A "rule of thumb" is that lock-up is supposedly worth up to 2mpg on the highway versus a non locking tranny. Everybody's actaul results vary.
1978? Err, no. I'm not a walking encyclopedia, but I know a little.
The C3, C4, FMX, and C6 automatics were never lock-ups.
C3 transmissions were used up until 1986. They began to be supplanted by the overdrive and lockup A4LD's beginning with 1985 Ranger 2.3 pickups.
C4 transmissions were used up until 1981. In 1981 the C5 was introduced and was used up to 1986. The C5 was a redesigned C4 that had lock up capability in third gear. THis involved a totally different valve body assembly from the C4 and a unique torque converter but a C5 actually shares a LOT of parts with a C4. A C5 generally doesn't fare well in performance use though and never gained much popularity.
The "mechanically controlled" AOD first appeared in 1980. A true overdrive with high gear lockup. Use continued until 1994 when it was replaced by the "electronically controlled AOD", the AODE. In 1995 it was redesigned again as the 4R70W.
The last year the FMX saw use was 1981.
The C6 hung in the longest. The last C6 was to be found in 1996 F350 5.8 trucks. It's replacement, the electronically controlled lockup overdrive E40D was introduced in 1989 and gradually replaced all C6 usage.
"Lockup" is not only for overdrive. Many modern transmissions have lockup capability in third and even second. Not to mention the newer five and six speed automatics. All in the pursuit of an extra MPG or two. No bad thing there, but it sure can make them complicated and expensive buggers to rebuild.
