Trying to figure out the optimal bore size for my application. 2008 Mustang GT dual piston calipers with a bore of 1.693" (I think). Rear brakes are stock C code drums.The booster is the aftermarket 7" variety. Need to try and keep the booster as I have sciatica on and off depending on how my back doing. Current master cylinder is a 1" bore 1967 mustang disc drum. Pedal goes close to the floor but stops the car "OK". 1/2 a gallon of brake fluid was pressure bled through the system with no bubbles. Master was also bench bled far longer than necessary. I ordered the Mustang Steve pedal pin relocater and 9"booster kit but will only be able to relocate the pin at this time because the 9" booster will not work with my current MDL hydro clutch setup.
From what I have researched going to a larger bore increases volume but not necessarily pressure. A smaller bore increases pressure but needs a longer stroke to do so. I don't care what the MC looks like at this point as long as it gets the job done. If it had a port for the hydro clutch to tie into like my Focus ST had, that would be crazy awesome!
