UPDATED SEE MY SECOND POST : So I purchased a FR tilt column with microsteer EPAS system. Everything is in and functioning except that the only way I can get my horn to sound is if I ground the horn with a jumper. FR simply says to ground the G wire but that doesn't even follow their own instructions. The column/switch needs a ground which isn't there. their own diagram shows an external ground and then hooking up to the ground lead of the relay as a trigger,
I have a painless wiring harness that already had a functioning horn relay but it was using a a positive trigger. Painless has instructions for swapping it over to a ground trigger but the wiring numbers colors are for a newer harness than I have. I called painless and they were helpful but unfortunately they weren't able to help solve the issue. This is where they left me
My crude drawing shows where I am now. wire colors are correct.
what I need is a ground for the column that will complete the circuit. right now if jumper from ground to the horn contacts I can close the circuit but the column needs ground too.
I saw a few posts that alluded to the fact that the column needs to be grounded but neither ididit or FR specifically say how to do that. i would think the column would be grounded by default but there's no continuity to the column and the dash. now the aluminum mounting bracket and the dash yes, but the powder coated column, no.
could it be the powder coating preventing a good ground? I would think that would be addressed before now.
Any help would be greatly appreciated.
thanks
Shawn
thanks
Shawn
