Which brakes - consensus from the masses???
9.6K views 39 replies 20 participants last post by  cougar70
Looking to get rid of PO front disc installation and replace with something better.
Wilwood or Baer???? Or...???
What say ya'll???
#6 · (Edited)
I used Mustang Steve 2008 GT adapter plates on my car. I autocross my car and wanted non commie parts as much as possible to do so. With research was able to get it done using factory caliper cores and EBC rotors and pads. The most favored nation reproductions of the original Kelsey Hayes front disks will get it done for the street. The factory rear drums are more than adequate for anything but high MPH track days.
756406
You shouldn’t Cheap out on brakes,.....,,
Like what has already been mentioned..... what kind of driving are YOU going to do with the car?
What'on the car up front right now?
ex-Global West GM
1991-1995
Reactions: rbohm
The plan is to have a nice weekend driver, maybe a couple cruise-ins and/or local shows. The car will have a little more zip than normal but nothing outrageous. Could be some extended road trips with the wife and pooch. It will have completely new suspension and steering linkages. It currently has disc on the front now (PO executed) but I have no idea what brand or reliability. It stopped ok before I began the tear down but man was it ugly looking (see photo). When I get it back on the road I want it to have great stopping power and look good as well.
756543
I just put the wilwood 13" 6 caliper discs on my 65 FB. I also installed a Wilwood master cylinder. I did not use a 1" MC although everyone and their brother recommends the 1". I used a 15/16" Wilwood MC and I could have used a 7/8". The brake pedal travel is not that much even with the 15/16 MC and the pedal stops way above the floorboard. I've had experience with 1" MCs without power assist and they require more leg force than I like. The 6 piston Wilwood calipers have just about the same piston area as the Kelsey Hayes I took off so they really don't warrant a 1" MC. The 6 piston calipers have one large piston and two smaller trailing pistons. I might have considered a 1" if I were putting 4 piston discs on the back also which would have had more area than the Granada drum pistons have, but I still may have used a smaller MC. I have the Kelsey Hayes 11" setup complete if want to buy it for $300 plus shipping.
#27 ·
it also looks like an aftermarket adjustable valve as well. grab one from a 67-70 mustang and plumb that in. NPD has everything you need
calipers and rotors, and brake lines
proportioning valve
#35 ·
If you need to also put $ into your MC or hard lines, using Granada calipers might save you some $ over name brand calipers.
But I don’t know if Granada calipers can just bolt up to Mustang spindles? (I’m sure someone will chime in...)
Case in point, my car came with Granada spindles and Granada calipers plus a 2nd pair of new in box Bendix made Granada calipers. Also it had a Wilwood proportioning valve and a leaky OEM Ford 15/16” master cylinder (and likely sludge in the hard lines).
I’m replacing most of the brake system with all new NPD stainless pre-bent hard lines (~$100), a Wilwood 15/16” master cylinder ($180), Bendix Granada calipers ($0 free for me), Porterfield pads ($80), Street or Track braided steel Granada lines ($75), and Raybestos R Line vented Granada rotors ($75).
For ~$500, I feel like I’m getting a lot of decent performing brake components for the money,
#37 ·
You are correct.
Odds are good that the 1-piece design is the updated unit. (replacing the OE 2-piece)
ex-Global West GM
1991-1995
