Sure, I'd use it. First, I'd grab a piece of plate glass and glue some emery paper to it, lay the cover face up on the paper and gently work it in a circular pattern, checking occasionally until a nice, even pattern shows all the way around. You can do this to the face if you put your glass close to the edge of a table so the bulging bottom of the cover can hang off. Just make sure you keep the water pump mounting area flat to the paper. If you paint the cover, mask off the sealing areas or paint it after installation. Don't use stainless hardware..use chrome plated or coated stainless. Seal around the water passages on both sides of the gasket with Permatex Aviation Form-a-Gasket and you'll be good to go for another 100,000 miles.
