I'm planning on upgrading my front brakes to help combat the tremendous brake fade I experience. Current set up is the K/H 4 pistons with EBC redstuff pads. Manual brakes 1" bore MC. The rears are stock drums prop valve with a 10lb residual valve. The rears never fade or get too hot, they dont do much anyways due to the light rear end. No issues there
It stops amazing. No complaints there. Its after several repeated stops that the brakes leave a lot to be desired.
I was able to secure some very very cheap 2012 Mustang GT 13.2 inch rotors and calipers with pads in great condition. Im going to need new brake pads and tires within the next few months so I might as well take the opportunity to swap my 16x7 16x8 TT2 staggered setup to a square 17x8 TT2 setup
I have a couple questions for those have done the swap and are running 17 x 8 TT2 wheels. I've done plenty of research on the topic and have seen it done. By the looks of it, only a small spacer would be required to clear the caliper. My main question for the wheels is what backspace wheels did you use? The easier/cheaper wheel to get is the one with 4.81" BS
Second question. Just confirming that 65-73 v8 drum brake hubs are the same with the only difference being the bearing sets for the bigger spindle pins of later years? I am running 1970 big pin drum brake spindles. I stupidly threw out all the old drum stuff when I switched to disks but found a cheap front drum assembly for a 68. Was hoping to salvage the hubs from that assembly
Besides that, The swap seems pretty straight forward.
2000 Mile driving update:
Decided to update this thread after driving the car for a few months and putting over 2000 miles on it
I have taken the car to Big Willow and Radford racing schools track. It lives in the mountains 90% of the time. I was pretty consistently out braking a 67 Mustang running the K/H system with ducts. I was able to brake harder and deeper into some corners and the brakes didn't even begin to cook
I have installed some DRP wheel bearing spacers which have made setting the wheel bearing preload 100X easier. Torqued to 30FT/LBS. Negligible amounts of bearing deflection and reduced pad knock back was also noticed.
No wheel on caliper contact and no wheel weights have been lost during the thrashing sessions and high cornering loads.
Very happy I did the swap!
