Hey all.
Pretty new here. Bought a 65 A code convertible for "the wife". Getting familiar with it.
Trying to identify the carb so I can either rebuild, repair or replace.
No tag, but the number stamped on the front lower left is C8VF J. From what I could see locate its a 1968.. but the V and the J I don't see any where.
It doesn't run terrible.. just leaks a little around the shaft on the top which I assume is the accelerator pump rod. Its also a bit rich.. The auto choke is opening completely when warm. I have adjusted the choke so its off all the time and it still runs a bit fat.
Questions:
Is it a 4100?
Is this an acceptable carb to run or should I get a 1965 4100? Car is pretty original
Am I better off going to something like the Edelbrock 1403 or the SUM-M08600VS
Any help or suggestions would be great.
Thank You
Questions:
Is it a 4100?
Thank You
