Hi Guys. I have my good friend. He purchased a 1968 CSRP front brake disc conversion. Not knowing much knowledge. Had a indie shop do the conversion.
The kit that was sold to him was a cast iron single piston kit. Why wouldnt
CSRP advise him to install a fix 4 piston caliper. Anyways. It sucks we tried
everything pedal goes to the floor,bled it 15 times it stops but too much pedal
travel. He does have a built engine,cam etc.. Why doesnt the brake company
ask these questions. Long Story Short. Does anyone any expert. Know if the mounting on the spindle assembly will accept a kelsy hayes type fix 4 piston caliper. Were trashing this cast iron single piston dead weight in exchange for
something lighter. also who can recommend a vacuum type reservoir to sustain the required addl vacuum needed due to the larger camshaft.
also this shop is recommending installing a GM style portioning valve i guess he says its a 50/50 split compared to the 60/40 with the one supplied with the kit.
? Thanks for your help. As for my 65 Fast Back Project still in the works.
