Anyone know what rotation on a omc cobra 5.0 HO motor? Would it work in my car
4.3K views 43 replies 14 participants last post by  Rdbronco
5.0 cobra HO crossover
Out of curiosity, why should it matter if its reverse rotation? Something to do with radiator flow? I mean Honda uses reverse rotation engines in cars just fine...and the only difference I can think of is that they also use cross-flow radiators instead of downflow.
Is there a gut of used boat engines out there? Seems 302 or 351 from bone yard would be the simpler solution. Auto engines use anti-freeze that has anti corrosion additives. No so much for lake, or worse, salt water. I seem to have recognized more load on a boat engine than a car engine. What might seem a "bargain" might end up being a money pit...kinda like a boat. ;)
They could be low hours but remember they are also some if the most neglected. While some are reverse rotation it's only one in a twin engine set up. I know a guy that loves to pick them up says the internals are stronger.
Most 5.0's are standard rotation. Reverse rotation engine are generally used with twin engined setups. And most twin engined setups use the bigger 5.8's. Or even bigger engines. I'm not a "boat guy" but I haven't seen any dual 5.0 boats. Doesn't mean they don't exist. But anyway, the 1985 Mustang GT camshaft wasn't made for that car, they just used a marine 5.0 cam grind designed for conventional rotation boat use. If you have a marine 5.0 with a roller cam, odds are it has a "Mustang GT" camshaft in it.
I put a truck 5.0 in my '67 purely as a placeholder for the 351W I finally put in it. Thinking of doing the same with my '69 as I have ready to run 5.0 and the 351W for it needs a full rebuild.
If it reverse rotation the the engine spins the opposite way…….
to the original poster, it is most likely standard rotation If it’s from a Cobra outdrive. OMC and Mercruiser for that matter started using the drives to achieve reverse rotation….guessing that was early 80s.
I understand it spins the opposite way...but why does it matter? Is it only because the factory radiator is downflow? I mean, say thast you used a crossflow radiator from a T-bird or something, could you then run a reverse rotation engine without issue?(always assuming your accessories are reverse rotation as well. not sure if that matters for the alternator?)
The crankshaft itself is reverse rotation. Twin engine boats use an engine of each rotation direction as opposite prop rotation is beneficial.
That does answer the other question as to why the marine motors were reverse rotation, I can imagine with 2 standard rotation engines the props would have a tendency to always induce a mild turn.
Just the camshaft. On many old school flat tappet cams it probably doesn't matter. But many roller cams don't have concentric profiles. The "lift" side is a slightly different shape than the other side of the lobe. With some cams you can even see the slightly lopsided profile shapes by eye.
The water flows the same way. The water pump will be made to do that. If and engine has a reverse rotation crank, the hatching at the rear where the rear seal rides will be opposite of a standard rotation crank so as to scrub oil back into the engine. If used in a normal rotation engine it will be trying to move oil out past the seal. Also, the camshaft is different.
#23 ·
I'll state the (hopefully) obvious. An engine spinning the opposite direction will output its power likewise in the opposite direction. Assuming everything bolts up, you now have a 3 or four speed in reverse and only one speed forward. Probably not what the OP is looking for.
#35 ·
lol, can't believe I didn't think about that. It does open some up some interesting possibilities though. IE: Use a reverse rotation engine in conjunction with a flipped Porsche(or I suppose Corvair) transaxle in some mid-engine build?(usual Corvair mid-engine conversions flip the transaxle upside down to compensate which requires some trickery). Though I guess that's a lot of headache when you simply use late model Corvette pieces instead. It would be useful I guess though in a rear-engine conversion on some car using a Subaru transaxle. Oh the crazy dune buggies you could build...
#28 ·
No, not really. There are all kinds of ugly spots on engine block castings. Look down the hole where the distributor goes, they all look like someone broke them with a sledgehammer in there. Every one.
If someone welded that I've love to have his name and number. People who can weld up big chunks of cast with such fine results are hard to find.
#29 ·
Yeah I did look down cylinder wall . Dint see one on other side ..I was like no.. one cylinders has some scoring but it rolls over smoothly.
#33 ·
In some of the op's other photos of the block area there were grinding marks all around on the hump area in question, and it looked to me to have a weld bead there...so, I think there was some crack repair. If it is just a water passage under that area I would think the repair, done properly, would be ok. Op has been very busy with his posts, photos, and replies since he appeared 4 days ago.
