clay bar/detailing
1.3K views 11 replies 10 participants last post by  hotrodder68
My car's pretty dusty from sitting in a dusty garage all winter. A couple of you mentioned the clay bar treatment for something I should do to clean up the paint... I have done this on both my Toyota and my van before, but only after a standard washing. I washed them, did the clay and then did the Meguiars three-part system.
On the 65, do I need to handwash it carefully first, or will the clay and detailer do the trick? Is the three-part OK or is there something else I should use?
Also, what do I use on the chrome? I haven't had chrome on a car in the family since I was about 11.
By all means, wash it, or your clay will become so over-polluted it'll be like block-sanding your car...
Then clay, then wax..
Just wax your chrome. Chrome "polish" I've always found to be totally unnecessary. The act of waxing the chrome will arrive at the same amount of shine, AND protect, in one step. The wax will help prevent pitting/rust.
Use metal polish only where you've got severe deposits or residue on the chrome, or to spiff up bare aluminum..
As Todd said, Wash good, then 3 stage Meguires Clay bar system( just did this a few months ago, man what a difference) as far as the chrome I just use regular Turtle wax chrome polish.
Congratulations Brian, now you are a real member of the club!!!That's how I felt at least....Did you know there is a self serve car wash right down Nammans road??If you come down my way, the traffic light before the light for the total wine/home depot, make a right and quick left, it's next to the overpass, and next to the railroad tracks. I took my stang there and gave it a good blasting, and I gunked the engine bay/front end, and blasted it off. It worked wonders. Another first I did was install a pertronix ignition, get rid of those points and condenser....I have a rust bubble on my door, I'm just leaving it be, I want it cut out and patched with some sheet metal, I have 3 holes[small] I need to have patched, I was told that is the proper way to deal with them....
Milo Bloom said:
Thanks guys. Is there anything I should do about this small rust bubble on the door? Or should I just leave it for now?
You need to clean out the drains inside the door, which is why the rust spot formed. Rust only gets worse, so fix it as soon as you can.
I've used Krown as a rust inhibitor successfully for years. Had a 1983 Jetta I finally got rid of 4 yrs ago, still had 80% orig paint on it, 660000 kilometres, driven every winter, still looked great. Krowned every year. I've seen the documentation comparing it to Rust check, Ziebart, etc etc. Cities around here use Krown to rustproof their municipal salters.
A rattle can of it runs around $10.
Might go by different name stateside, but worth a try.
I just finished up Zoop Sealing my chrome. Pricy but one deluxe kit did the whole car. Interesting stuff. You clean with their cleaner, apply the zoop seal, let dry, then buff off with a purple cleaner solution. The zoop seal leaves a film that the purple cleaner takes off and the chrome really shines up. Can hide minor scratches and does ok with older chrome. On my magnum wheels with the black paint, I just applied and didn't buff off. Supposed to last 2 years, I'll let ya know....
Greg
