Aloha everyone. Once again, I have a leaking intake manifold at the manifold to head mating surface. I verified this by spraying carb cleaner there, and my idle definitely increased. The car's still hot so I haven't pulled the carb off it to see if the bolts have loosened up (again). So, I'm looking for some advice on why this might be happening.
Here's the long sad story: Original 289 block and heads from '68, Edelbrock Performer 289 aluminum manifold. When I had the engine rebuilt in 1999, the machinist cleaned up the surface on the heads. I don't recall hearing a specific number of thousandths he took off, but the goal was a true surface, not increased compression . I don't remember if he also did a clean up cut on the block surface, but I'm assuming he did. I also remember the machinist telling me he milled the intake manifold to head surface to match up with the trimmed heads. (and I've compared the surface texture on my intake manifold to one fresh out of the box and it certainly looks like it's been milled (circular lines from cutting tool).
Once I got the engine back in the car and started driving it, it would run fine for a while, then run rough. Vacuum gauge showed a leak, and spraying carb cleaner on the manifold to head mating surface improved the idle. Looking closer I found that the intake manifold bolts had come loose. Tightened them up to spec (20 lb-ft per Edelbrock specifications). Kept happening over and over. Changed the intake manifold gaskets a few times myself, tried once with a local shop, tried different torque wrenches, nothing helped.
Then, the car sat for 14 years. As part of my work to get the car running, I pulled the intake manifold and ran a tap down the bolt holes to clean them out. One of my theories on why this kept happening was that the bolts were bottoming out in the hole and therefore not clamping the manifold all the way. Welp, found out that those are through holes. I also changed from ARP stainless steel bolts to local hardware store grade 5 bolts that were 1/4" longer.
So, should I use blue locktite on the intake manifold bolts? Lock washers? Longer bolts (looks like I can easily go 2 1/2" long)? I've been using FelPro gaskets, but I don't know what part number they are, so a different gasket?
I believe that @LSG mentioned one time that you should never mill the intake manifold. Can that possibly be the reason for this? I do have another Performer 289 available, but I had the one on there port matched and don't want to go backwards.
Mahalo for your assistance!
Harry Z
Harry Z
