Distibutor recurve question
2.6K views 26 replies 13 participants last post by  rpm
What do I send? Complete distributor with cap and rotor? I am sending two distributors, one has points, the other has Pertronix. Do these need removed? No one is answering phone at the Mustang barn and I would like to get these packaged and sent today. Thanks in advance.
Probably could send it stripped as they’re going to be setting the advance curve. However I would send it complete. This way they can go though everything and make sure everything is set up correctly. Once back, you’ll just have to drop it in and set timing to their specs.
Getting the distributor recurved is probably one of the best things you can do.
I agree that you need to email first. I did this and received a form to fill out with pricing, etc. I have not sent in my distributor yet since I am working out some other issues (same as Maverick_tlc), but plan to do so at some point this winter.
But definitely know what work YOU want done (simple recurve, repair, full rebuild, etc.) and have the form filled out before shipping the parts. It sounds like the turnaround is pretty quick, and yes, I would send the entire distributor...
I have already emailed and received forms for both distrbutors. It doesn't say on form to send entire distributor or strip it down. It does ask if using Pertonix to state the model. If I'm sending the entire distributor why would they ask that? I'll just send the whole thing.
Ya, his questionnaire and instructions are a bit thin.
I don't know what shipping instructions they gave you, but I suggest pulling it, allowing it to drip for a day. Then I wrap it like a cocoon with paper towels or shop absorbent towels, then raid the kitchen to seal it up with an excessive mummy-wrap of plastic cling food wrap so it cannot leak in shipping. Oil creeps. ;)
You (or your receiver) don't want the headaches that shipping companies give when something leaks an unknown fluid ("OMG!! 😱") in-transit.
You should have sent Dan an email first indicating your intentions. He would have replied with shipping instructions, aka, what to send. Also, you need to provide how your engine is being used etc. Don’t rush it, have you heard the saying “ haste makes waste “?
Reactions: 67six
#10 · (Edited)
When I shipped my 67 Motorcraft Dist. (came with my May built '64) to "Dan", he requested the distributor minus the cap with whatever "sparkie" I planned to run which, in my case, was a P1. I added, my engines intentions, (spirited street) tranny info, rear ratio and Cam Doctor program sheet. My distributor was already in pretty good shape, mechanically. Thus, no need to get into the shaft bushings etc.
Editing to add....what I received in return, was a nicely re-curved distributor with an all-in at 2600 Rs, a recommended initial, with a mechanical of 19º. Was worth it to me.
The info should be as complete as possible. Camshaft, transmission, rear axle ratio, rear tire size, and type of driving would be the minimum. Send him the whole thing, from bottom to top, including the cap. If it's nasty, spray it down with brake cleaner, and air blow it dry.
Just to follow up, I sent both complete distributors minus the caps. One got a complete rebuild and recurve and the other just a recurve. After reinstalling I think I might feel a slight seat of the pants increase in power or maybe it's the cooler weather. Anyway, I am satisfied with the service Dan provided and it is reassuring knowing the timing curves are just right. Now all I need is for spring to get here.
I used to do a lot of distributor curve work, and I never saw one that was "in limits" when tested. Oh, and "remanufactured" distributors were the worst.
At one time, popping the distributor into a Sun machine was part of a normal tune-up. Nowadays, most shops wouldn't know what a distributor machine was. When I think of all the money people spend on carburetors, coils, and other engine upgrades, but do nothing to address distributor performance…
Fortunately, while it is a bit more clumsy, most things a distributor machine is used for can be done right on the engine with a timing light and a hand vacuum pump. (y) Unfortunately, most hobbyists don't have the concepts of what they can do for free. So, it's shipping off to the distributor shop, when a read-up in the FSM would get it done in about the time it takes to pull it, pack and ship, not to mention the down-time and cost. If you can rebuild a carb, you can rebuild and adjust a distributor. 😊
#23 ·
Exactly my thoughts. I never understand the hassle & downtime sending it off to Dan when you can do it yourself. Of course, not everyone has the tools and skills.
This post has been deleted
#26 ·
#27 ·
Fortunately, while it is a bit more clumsy, most things a distributor machine is used for can be done right on the engine with a timing light and a hand vacuum pump. (y) Unfortunately, most hobbyists don't have the concepts of what they can do for free. If you can rebuild a carb, you can rebuild and adjust a distributor.
So if you are trying to make me feel inadequate you failed, try again.
I certainly didn't read anyone trying to make you feel inadequate.
