Driveshaft options for 8.8 in a ‘67
704 views 20 replies 8 participants last post by  Dan Babb
wondering if anyone has ever ran a stock ‘67 driveshaft paired with an 8.8 rear end. need to figure out if length will work, if so what type of yoke would work.
thanks!
The crown vic police cars also had the aluminum driveshaft. I don't recall the year range, but do a search here...that's how I found the info. That's what my alum driveshaft came out of. I did shorten it to work with my t5, but I have a 9" rear, so no help with u-joints to make it work with your 8.8.
Hmm. I have a flange for an explorer somewhere. But it's in another state. I would give it to you for the postage if I could locate it. It came off my Explorer driveshaft I bought from a yard. I don't need the flange with an 8" rear. I actually got two driveshafts that day, $50 each. It was the right length for my toploader once I swapped the front yoke with a Ford Motorsport one and got the correct rear joint.
So maybe call around junkyards. I use this site to find the yards that may have the part but ALWAYS call to verify they have it as the site is not always super up to date. But it's how I found mine. And you need to check if it's bent. A lot of them get bent because yards move junk cars around with a big forklift. You most likely are going to have to have it shortened. I'm not sure what length will fit yours:
#8 · (Edited)
do yall have any links on what yoke to look for?
As I recall, it was from a mid- to late-1980s F150.
Note the combo U joint was still needed:
You can see what I did to the shock plates here.
I used my stock driveshaft and a pinion yoke from a F150 8.8. It still uses a 1310x1330 combo U-joint, but is smaller diameter (maybe a bit shorter) than the Explorer pinion flange. As I recall, a Ranger may have a smaller diameter pinion flange. I didn't center the pinion and my car sits low, so clearance was more critical for me.
I have a V6 2-wheel drive 4-door Explorer aluminum driveshaft that I may use if I center the pinion. It is about 3.5" diameter but hits my transmission tunnel due to the offset.
Another thing I did was use the differential cover & mounting bolts from a 2001-2004 Explorer IRS 8.8. It is finned aluminum, provides extra cooling, has a drain plug, and adds a bit of strength. I cut the mounting tabs off plugged a vent and mounted it up. It is what some early 2005 GT500KR Shelbys had.
You can use a truck 8.8 yoke. I didn't have to shorten my driveshaft when swapping in an Explorer 8.8 with the truck yoke and T-5 for the 8" and C4.
