My 65 mustang has been stolen. Neighbor said it left on a red rollback. VIN is 5F09K677490. I had dismantled it to prepare it for acid dip and ecoat dip. New ford racing 8.2" engine block , Bryant Racing crank , JE psitons , 4 into 1 FPA headers also stolen along with drill press , emergency generator and gas cutting torch. The mustang has unique mods and its one of a kind. You would destroy it if you tried to put it back stock. I have posted many old fotos of mods I have done many years ago. I dont have any current fotos but they would show the same mods and then a few more. It has 6 uca holes in each shock tower. Stock , 1-3/8" and 2-3/8" drop holes. LCA has 1 set of holes 1" lower than stock in 1/8" steel plate. 1.5x2.5x11gauge straight lower crossmember. A 6x6 piece of trunk sheet metal was cut out above each rear spring eye. A 6x6x.187 steel plate was welded directly to the rear frame rails right above the rear leaf spring eye and the rear trunk roll bars are welded to them. The dash has a blank steel plate welded over the radio opening. The roll bar side bars are stitch welded to the roof frame and a-pillars. It has 69 factory wrap around shock towers and 14 gauge side filler pieces. My scanner is broke and my hands are shakey when i took fotos of the police report. I am very stressed right now. It was stolen from the San Fernando Valley Los Angeles Ca. Btw there is a tap(no slap) on the finger for auto theft in California.
