I want to clean up the wires in my engine bay, but I don’t like the look of that plastic wire loom stuff. What do you guys using to make it look nice?
I use this stuff as well.....works and looks great.I have been using this product for a while, and I really like it. I use a piece of heat shrink on the ends to finish it off and keep it from fraying.
https://www.amazon.com/Alex-Tech-25ft-Protector-Sleeving/dp/B07FXF12HC/ref=sr_1_3?crid=3F4K13HBF3KSA&keywords=alex+tech+split+sleeving&qid=1670941984&sprefix=alex+tech,aps,188&sr=8-3
"TESSA" brand tape might be what you have. That's a good option for "wrapping" it like the OE style and holds up pretty well. Otherwise as others have said, the expandable split-loom certainly is a good option and looks better than the stupid corrugated stuff. Your other options are going to involve (or at least be easier) disassembling the whole harness which usually is past what most folks want to do.When I was prepping/cleaning the harness to reinstall in my car I had bought a few rolls of friction tape similar to what the factory used. What I found had a little more cloth texture than the original stuff, but it was as close to the factory stuff as I could find. Wound up not using it because the original wrap on my harness looked so good after a cleaning. Biggest thing with underhood wiring wrap is heat, so want to make sure you're using something that isn't going to melt.
Self-fusing silicone tape. No heat to accidentally ruin the loom. I use the heavier Plymouth/BISHOP 20 mil Plysil on my custom harnesses (but there are many brands), and it works nicely to wrap at those branch junctions and exits without any sticky stuff. Use clean fingers.Once I have it all together, I use that black silicone tape that bonds to itself when I wrap it around the end of the loom.
