Valve stem seal replacement saga continues. I'm sure that someone far more competent than me would have had this done in less than an hour. But, you know, I'm me and everything...
So I've run into an issue with almost all of the intake valve spring retainers. They will NOT break loose. Need ideas on things to try beyond what I have already tried.
Here is what I have tried:
1) Break loose retainer by placing a spark plug socket over top of the spring and hitting it with a hammer (have done this for all valves). I hit it until it makes the "pop" sound... and then hit it some more after that. I've done this while combining with any combination of the below techniques...
2A) Use stud-mounted valve spring compressor. Compress the hell out of it. Bent the rocker arm stud and the spring keepers still wouldn't let go.
OR 2B) Use spring-mounted valve spring compressor (with the twirly part on top that you spin by hand). Compress until the spring is literally not touching the head anymore. It's still stuck on the retainer and I can't get a good smack with the hammer on the top of the compressor - afraid of bending valve stem if I get at it at an angle (will this bend a valve stem? not sure how delicate they are).
3A) Use 100 psi compressed air.
OR 3B) Use the "rope trick". Think that I need more rope as the cylinder wasn't quite full of rope even with the piston at TDC, so the valves still had some movement. Kind of made me nervous after I managed to get a corner of a piece of rope stuck between the valve and the head after taking the spring off and putting back on (easily fixed by just recompressing the spring to let the valve down a bit but made me think that it would be easy to damage the valves this way) so I haven't re-employed this technique since.
I've only ever done valve spring removal with the engine out of the car, so trying to wrangle around all of the bits and pieces in the engine bay is really hanging me up. But I find it very odd that it's just the intake spring keepers that are giving me trouble - exhausts come off just fine. So of course now I want the intake springs off more than ever because I feel like there's a problem with them.
I'm afraid I'm going to hurt something if I keep smacking it with a hammer. On the one hand, these things are subjected to a huge amount of force all the time, but on the other hand that force tends to be very linear. So I'm not sure how much muscle I can put behind this.
Any additional tips would be very helpful. Otherwise Jane is going to California with half of a set of good positive valve stem seals and half of a set of bad hard umbrella ones... :shrug: And knowing Jane, probably the intake umbrella seals are the ones that're leaking in the first place anyways.
Can't tell if I'm just making this harder than it needs to be or if it's just Jane being Jane.
