1 - 20 of 24 Posts
pdubbb1
· Registered
Discussion starter · #1 ·
Hey, can anyone recommend a good driveshaft shop.
I need a 58 & 5/8th inch shaft to mate to a 1330 series yoke and a 6r80 transmission with a factory flange. I prefer a 3 inch diameter shaft that can handle about 8000 rpm.
been have a hard time trying to find a shop that is reasonable priced to build this.
can anyone recommend a place?
This is a situation that you open up your local yellow pages...and find a drivehsaft shop. This is common stuff that any local driveshaft does at a reasonable price. Its only when you try to get work done by a big guy(IE driveshaft shop) that prices get out of hand. Last time I went down to the junkyard...pulled an aluminum aerostar driveshaft(yoke is suitable for T5 and C4 splined things if I remember correctly) and had my local driveshaft(Clinards here in Nashville) shop shorten it with a conversion u-joint and flange suitable for a Ford 8.8 rear. I was out the door for about $200 including the cost of the driveshaft. Of course...that was 10+ years ago...I would expect that to be about $300 or so now
Given that the SoT is $350 for a new aluminum driveshaft it's questionable if trying to find a junkyard, pull yourself and then still have it shorted and balanced is worth it.
Depending on what you want/need local could be the best bang for the buck. If you are looking for high HP/TQ application and may want someone more specialized.
My 1000HP rated aluminum came from these guys. Recommended by MDL / Modern DriveLine.
That would depend. For instance I can't use a SoT driveshaft because my transmission does not have a slip-yoke, only a flange, so any driveshaft I get made will require the slip yoke in-shaft. Of course I doubt I can even find an aluminum base to start with that fits my parameters(though maybe some late-model Ford has what I need). I would likely have to get it built from scratch....which would definitely be cheaper with a local shop.
Mine came without the yoke. You specify the u-joint size that works with your yoke and install it when you receive your driveshaft. Should work fine, unless I’m not understanding your application.
I have a 8"(soon to be 9") rear end...and a MT82 trans...which means that my driveshaft needs to have a built-in slip yoke like this(under the boot):
Makes it pricier than your normal aluminum driveshaft....most online retailers charge $900+ for stock application replacement in aluminum(though usually they are converting from a two piece to a one piece at the same time)
Thanks for the clarification.
Discussion starter · #17 ·
this is something along the lines of what i need. I contacted shaun from street or track and he said they dont build nothing special. i need a 1330 series yoke on one end and a slip yoke on other with this flange
on the other. Not so sure whats so hard about it.
Also want it be able to handle about 800 hp's because I might install turbo in future
Seriously ? holy hell thats a deal. i know who im calling lol
Mark Williams, Strange Engineering, Denny's Driveshaft
All very good products. I have a Dennys what they call nitrous one in my drag car and I beat the crap out of it for years.
When I made a transmission change I needed it slightly shorter and a different transmission yoke and they were very reasonable with modifying mine and still has their guarantee not to twist.
Discussion starter · #20 ·
i think i will give dennys a try.
1 - 20 of 24 Posts
