after install of heads did a dyno run and not happy with the results. currently have an 302, .30 over with Shelby al intake holley 650, vac sec and Shelby style headers. thinking of an upgrade in camshaft from an comp 256h to a comp with .509/.512 lift. called comp cams and they recommended this as this is an hydraulic flat cam. have forged pistons with standard relief. called afr about lack of hp and what to add to the heads to help them out. no help or ideas from them. also running a t-5 with 3.50 gears. I believe the best I got was 269 at the crank. factory rated j code from 68 listed at 320hp. runs fine but the cost of heads should produced more. total time is right so what might I expect moveing up a bit in cam? really no engine builders in this area anymore for advice or help. what do you think?
