Hello all,
I'm planning some work on my 1970 Mustang this winter. I am a college student and will have a full month off of school in December and January. Except for my weekend job, I'll be able to work on the car full-time.
I'm hoping to start by early November, and in the meantime I may start looking for some parts. The main priority will be rust repair, but I want to do some other work while it's apart.
Currently, my rough plan is:
Remove engine, transmission, rear axle, all sheetmetal in front of windshield
Remove windshield, dashboard, underdash wiring, pedal cluster, interior
Drill out lots of spot welds plug weld in a new cowl (I'm new at welding by the way)
Replace floor with a one-piece reproduction floorpan (old floor is a little thin in front, rear is fine but everyone says one-piece is best)
Repair any other structural rust I find
Repaint undercarriage, engine bay, and interior for rust protection
I may install a trunk firewall and subframe connectors while I'm at it
Get my wiring harness restored (I'm having a weird issue with LR turn signal)
Install a clutch pedal roller bearing conversion
Replace all brake hard lines that are still original
Reassemble with a new carpet, new hard fuel line, and retensioned or replaced leaf springs.
I can afford to spend up to $7,000 on this, but I'd like to spend much less. I think I can if I spend much less. One concern that I have is that I'm still quite new at welding. What if I run into a problem I cannot solve while installing the cowl or floorpan? For anything else I could rent a trailer and take the car to a professional, but it's my understanding that moving around a car with no cowl or floor is a bad idea and could result in the body bending.
As an alternative, a local guy has quoted me $2000-3000 labor to install a new cowl, floor, and whatever else is needed. It's a guy on Craigslist, which makes me a little nervous. I may contact some actual shops and see what they quote.
I like the idea of doing the work myself, but I'm nervous about getting in over my head and having my car take up permanent residence in the garage. If I get really stuck on a structural repair, is there anyone on here near Indianapolis who could come to my garage and bail me out? I would pay you of course.
