To clear up confusion over what a "2+2 fastback" really is
41K views 78 replies 38 participants last post by  pofomoco
#1 · (Edited)
There seems to be considerable confusion about what 2+2 means when discussing a fastback. I've heard a lot of people think that it means that a fastback has a sport deck and point to the fact that the '65 and '66 fastbacks were given "2+2" badging and all of them came with a sport deck. For '67, the sport deck was optional and the badging was gone. So, this loose correlation is erroneously taken by a large number of people that I run into to identify what a "2+2" is. However, the sport deck has absolutely nothing to do with the marker. The badging doesn't have anything to do with the marker, either. Mustangs were marked with "F-O-R-D" across the hood from '65 until '67. In '68, the "F-O-R-D" badging was removed (added back in '74 for the II) Does this mean that 1968 through 1973 Mustangs were not Fords? Of course not! I believe that noticing that Ford dropped the "2+2" badging for '68 should be considered with the same line of thinking.
[edit]
To add, the sport deck did not disappear in '67 and '68; it was just converted to an option although choosing this option did not get your '67 or '68 badged as a "2+2." This adds considerable confusion to answering exactly what Ford meant when they unveiled the fastback specifically labeled as a "2+2." Perhaps Ford meant something unconventional with their meaning and perhaps they explicitly called it out with the focus of it having a double meaning...that their fastback was a 2+2 in the conventional sense while also being somewhat unique in that you could fold down the rear seat and convert it to a 2 seater, while also being able to unfold the rear seat and optionally seat 2 in the rear when you needed to. The definitive answer to the question of the true driving force behind Ford explicitly marketing their 2+2 fastback as a 2+2 fastback is most likely lost to history unless someone with first hand knowledge of the marketing decision can shed some light on the subject. However, what we do know is that "2+2" has an explicit meaning that extends beyond any custom usage that Ford used for the fastback. For the purposes of this thread, I hope to clarify exactly what 2+2 means in the greater sense and demonstrate how Ford's "2+2" fastback is a 2+2 in the broader sense of the term, regardless of any nuanced meaning that would be pure conjecture to assume.
[/edit]
So here is what "2+2" really means (there are 3 major variations):
Variation 1 (The technical definition)
Technically, all Mustangs are 2+2s because they are rear wheel drive vehicles with a fairly large driveshaft tunnel that takes away the third rear seat. There are 2 bucket seats in the front and seating for only 2 in the back rather than the more common rear bench configuration that could seat 3. This is the only hard attribute for calling a vehicle a "2+2." The fact that they are rear wheel drives doesn't impact them being "2+2", per se. But, the driveshaft tunnel that runs longitudinally through the center of the car results in a large hump that impacts the seating arrangement and takes away the possibility for a 3rd rear seat; the fact that they are rear wheel drive impacts the rear seating arrangement. It is the seating arrangement that is being spoken of when calling a vehicle a "2+2."
The Ferrari Mondial was considered to be in the 2+2 configuration in this technical sense of the term. It is a mid-engined car that pushes the seats in the rear very far forward, leaving space for a small bag of groceries in either seat (I'm being facetious, but only slightly. The rear seating is *extremely* tight in a Mondial)
The Porsche 356(and its successor the 911) is in the 2+2 configuration as well. It is a rear-engined car with a large hump between the rear seats that eliminate the possibility for a third rear seat.
Variation 2(Marketing a 4 seat version of a dedicated 2 seater)
The term has also been used more pragmatically to allow a manufacturer to create and market a 4 seat version of a more common, dedicated 2 seater of the same model. (as in, the dedicated 2 seater came first and the 4 seater "2+2" is the new version of it)
Here are a couple of examples of vehicles that fall under this more manufacturer-centric version of the term.
In 1966, Jaguar released a 2+2 version of the Series I E-Type. Prior to '66, the E-Type coupe was a dedicated 2 seater.
In 1967, Lotus released a 2+2 version of the Elan. Prior to '67, the Elan was a dedicated 2 seater.
A 2+2 version of a 2 seater can be introduced by a manufacturer to gain market share in the "young families" market segment and can be used to respond to high insurance premiums found by their 2 seater owners by adding token rear seats for reducing total cost of ownership while maintaining an identical body style to the more expensive to own, 2 seat version.
Variation 3(The loose, colloquial definition)
The "2+2" moniker has no specific requirements other than this "2 seats up front + max of 2 seats in rear" specification but the term has come to loosely include other additional details such as:
>a sweeping, sporty rear roof line that reduces head room to rear passengers
>very little leg room as a result of the positioning of the seats with the roof line
>2 doors
(while still maintaining the 2+2 seating arrangement)
So, in review:
Variation 1: the Mustang fastback is a 2+2 under this variation. It has 2 seats up front + 2 seats in the rear
Variation 2: the Mustang fastback is not a 2+2 under this variation. There is no dedicated Mustang 2 seater produced by Ford
Variation 3: the Mustang fastback is a 2+2 under this variation. It has 2 seats up front +2 seats in the rear, a sweeping, sporty rear roof line, reduced head room to rear passengers, little longitudinal leg room due to the positioning of the seats in relation to the roof line, and 2 doors.
...The Ford Mustang fastback is a "2+2" under both the 1st major variation of the term and the 3rd major variation of the term. The sport deck is not a requirement for it to be considered a 2+2; it's classification as such has nothing to do with the sport deck.
Thanks for this clarification. I have owned and worked on vintage mustangs since 1987, and never really knew what the 2+2 stood for.
As it turns out, my assumptions were pretty much spot on.
I'm going to memorize that post and repeat it to those who ask about my car at the next show. LOL
(Amazing read! Thanks for the info)
Stan
I worked for the one of Ford engineers when the first mustang came out , he had one of the first off the line. He gave me a lot of info on the ways of this car , he also was instrumental with the development of the Ford Bronco and had one of the first of that too.
His Name was John Wells and he owned a summer resort in the Upper Peninsula of Michigan. He was a great guy!
#10 · (Edited)
Yup.
My interpretation of why Ford chose to market the fastback specifically as a "2+2" rather than just a fastback is just an educated guess.
1)The fastback was badged as a "2+2" because of the fact that it is actually a 2+2
or
2)The fastback was originally designed to be a dedicated 2 seater and someone changed the design for 2 additional rear seats. PERHAPS if this is the case, the folding rear sport deck became a compromise between the 2 designs.
or
3)Ford Marketing wanted to create the perception that the fastback was the sporty version of the Mustang by saying "this is our 2 seater version of the Mustang + 2 seats in the back."
or
3)Ford Marketing had no real clue what the term meant and used it with their own meaning
Personally, I'm interested to know more official word on exactly why they chose to add the additional badging to their marketing of the original fastback. Perhaps the reason is entirely superfluous, perhaps it's purely marketing, and perhaps there was contention between designs for the fastback.
#8 · (Edited)
Are we just speculating here, or is there some basis in fact dating back to an actual Ford employee involved with this?
Citing how other manufacturers have historically used a term or moniker is only indirect and circumstantial.
After all, did Pontiac's GTO really stand for Gran Turismo Omoligato??? No, it just sounded cool and European, so Pontiac hijacked it... The GTO was never "confirmed" for any racing series. Not to mention that Pontiac also used the 2+2 moniker for a frigging land-yacht of a 2-door hardtop..
This is all semantics, and only those who decided to apply the 2+2 moniker to the original fastbacks would be able to tell you their specific inspiration and application behind it.
I'll always consider it (for the purposes of the Mustang) 2 seats up front, plus a couple optional seats in back. Reading much more into it is way-way-way overthinking it, just as fretting over coupe/sedan/hardtop/landau/fastback has been 5,000 shades of gray over the years, and constantly mis-used or used differently simply due to marketing intent...
The 2+2 disappeared the moment they made the fold-down optional.. To say "that doesn't matter" by citing Ford's removing "Ford" from the hood in '68 is an extreme reach. There are still plenty of Ford logos and call-outs on a 1968 Mustang...
#11 · (Edited)
It didn't just *sound* European, DeLorean took it directly from the Ferrari 250 GTO all the while knowing exactly what it meant.
But everyone knows that Gran Turiso Omologata is what GTO means. Sure, Pontiac didn't produce the GTO for FIA racing, but it is well known that is what GTO actually means. Their market segment wasn't in tune with FIA racing and Pontiac decided they wouldn't care what it actually meant.
Whether Ford badged the fastback as a 2+2 for any purpose other than those I outlined, that is what 2+2 means. It is not a Ford term, just as GTO is neither a Pontiac nor a Ferrari term...whether they have used it for separate purposed or not.
The major points here are that
the fastback Mustang IS a 2+2 whether it is badged as such or not.
It IS a 2+2 whether it has a sport deck or not.
The Pontiac GTO is not approved for FIA Group 2 Racing. It is not Gran Turismo Omologata.
Calling the Pontiac "GTO" the "GTO" in Italy would not translate well just as the Chevy Nova or the Ford Pinto did in Spanish speaking countries (but admittedly in a hokey way rather than being interpreted as "Won't Go" or "Tiny penis.")
as I recall, the Oldsmobile "442" similarly became meaningless as the car devolved into a paint package with automatic transmission.
Well yeah...the 442 split off from the Cutlass as its own model because it had gained brand recognition. Once it gained brand recognition as its own model, other options that did not match the meaning behind the 442 name came into availability.
Another one: what does GT mean? I'm not asking, just adding to what 69bossnine said. Some will say GT is like what makes a Mustang GT a GT.
Torino is also Ford, The 71 Mustang is just a tad shorter than 71 Torino.
All 70 Torino Verts were GT. They were not availible with the base I6. They had a round chrome thing in the center of the grill with GT.
Standard was low back bench seat and column shift. They had a full width tail light.
Olds had the 4-4-2 is that strictly defined?
Slim
#13 · (Edited)
Slim
As you know, GT actually means Gran Turismo but it is a term that is quite commonly borrowed from FIA racing by American marques to identify the "racing version" of their vehicle, which is actually very close to its actual meaning. I'm not sure what you meant with your "Some will say GT..." statement and I'm not sure what you mean with your mentioning of vehicle lengths.
The 4-4-2 actually is pretty well defined by Oldsmobile. 4 Barrel carburetor, 4 speed manual transmission, 2 exhaust pipes
#20 ·
Point it product companies not just cars have groups whose main job is marketing. Decisions on a product are made by finance, engineering, manufacturing, sourcing and marketing.
On top of that is the CEO, etc.
Marketing/sales has the heavy vote on things like insignias, model name, even the name of the car model.
Names like GTO, Galaxie,500, 442, GT, Judge, Super Sport, 2+2, Euro, Sprint seem to be a good idea to draw attention to a model or accesory group.
My guess is Olds people have a fair idea of what makes a 442 a 442 but probably aren't totally positive. There's no Fairlane 442 that I know of, so what?
Slim
Good grief, talk about angels dancing on the head of a pin.
Two definitions at play here- generic terms for a body style/configuration, vs. terms the manufacturer chose to use.
As far as the generic term, yeah, a 2+2 meant a tight 4-seat car. Anyone who has ever sat in the back of an E-type 2+2 or a 911 will tell you that the back seat of an early Mustang has more in common with a limousine than either of those.
As far as manufacturer terminology, they can (and will) call it whatever the heck they want- that's why we end up with roadsters with roll-up windows, phaetons that aren't, coupes that are sedans, etc., etc., ad nauseum. Looking for logic there is a fool's game.
Words have a purpose, and that purpose is generally to communicate. Calling a '69 Sportsroof or a '66 coupe a 2+2 is exactly the same as referring to a Mustang convertible as a drophead coupe- you may be able to make a convoluted argument in favor of the term, but the poor slob you're trying to communicate with may make a less charitable assessment.
Call the dang thing by the name that the manufacturer actually used. Seems simple enough.
I created this thread to help clear up what the term means in the greater sense and how/where the Mustang fastback coincides with the variations on that theme. I wanted to explain how "2+2" is not Ford specific jargon so people curious to know what it actually identifies are armed with information rather than assumptions.
I believe I have done that.
Based on that definition, I have a Fastback/Sportroof 2+0 because it's just me and the wife.
#64 ·
most under the age of 40 dont know or care much about old tech. and those under 30 believe uber is the way to travel
#26 ·
...always loved that ad
#27 · (Edited)
The notion that there are one, two or three acceptable definitions of "2+2" is a false premise.. That's my point. If the guys from Ford marketing and branding were huddling sometime in 1964 and saying "you know, this 2+2 thing that's being used for this, that and the other is pretty catchy... Since our fastback is a euro-inspired deal, and we've got the nifty folding seat thingy going on, how about we call it 2+2"??
The definition of 2+2 is whatever the hell those guys wanted it to be at the time, generally-accepted-uses be-damned...
Just as the marketing/branding folks at Pontiac took the 2+2 moniker and wiped their rears with it's "accepted definition". (Google 1986 Grand Prix 2+2, and you'll see no change in rear roofline or headroom, just a horrid looking rear glass).
The true story of what it means in a Mustang resides within the tales told by those at Ford who made those decisions.
If you want to see why this is indeed dancing on the head of a pin, then Google "Roadster", and then see how Ford applied the word "roadster" to 4-passenger Thunderbirds in 62-63 simply by slapping a removable fiberglass panel on the car.
I'm not trying to be salty or sharp, and I certainly don't need the classic car history lessons :D , but marketers can put 2+2 on a Yugo station wagon if they so please, and say that it means "too-ugly and too slow" as a joke, and from that day forward, that is what 2+2 would mean for that model of car.
And just to paint one example of how Ford wasn't working from the "car term dictionary from on-high" back then, their first use of the term "two-plus-two" came in 1963 on the Mustang II prototype... which was..... a convertible...... Page 106 of Mustang Genesis by Bob Fria.
Perhaps I'll email Bob to see if he has any interviews or notes on the accepted use of 2+2 within Ford for the production 65-66 fastbacks. He can even buzz Iacocca if he's so inclined.
#28 · (Edited)
It actually isn't a false premise, although I'll leave open the possibility that I've excluded some detail.
There is a pretty good analogue to the usage of 2+2 with the Mustang that's already been introduced in this thread.
The Pontiac LeMans. Let's assume that Pontiac was able to submit the LeMans to FIA for Group II homologation and FIA approved them in English "Grand Touring Approved!" or "Grand Touring Homologated!" then Pontiac decided to badge their vehicle the LeMans "GTO" because it sounded European strictly out of happenstance with no thinking into the fact that their LeMans actually was Gran Turismo Omologata.
Then 2 years later, while maintaining their FIA Group II certification for their vehicle, they decided to split their "GTO" away from the LeMans but did not want to call the new model the GTO and instead decided to call it the "Broken Down Crap Wagon," removing the GTO badging. They then proceed to submit the Pontiac Broken Down Crap Wagon to FIA and FIA returns a ruling of "Group II Approved!" for the Broken Down Crap Wagon.
In this case would the "Pontiac Broken Down Crap Wagon" be GTO?
The answer is yes.
The motives behind *why* Ford decided to badge the 2+2 Mustang Fastback as a 2+2 are entirely irrelevant to the fact that, assuming they sloppily used the term to mean something that it doesn't, the '65 and '66 Mustang Fastbacks actually are 2+2....as are the '67,'68,'69 & '70 Mustang fastbacks even though they are not badged as such.
#29 · (Edited)
Not only have you lost me, I think you've lost yourself...
Bottom-line, I've got a very solid hunch that Ford's intention of applying the 2+2 moniker was because it segued rather ingeniously with both traditional-view of "2+2" and the fact that they had this nifty fold-down seat feature that they were keen to market that offered you in-effect "2 seats".. "plus another 2 seats when you need them".
I would highly doubt that, within all of Ford's product-planners and marketing ilk, they didn't consider the fold-down-seat HEAVILY in their decision to call the car "2+2", which is counter to your initial post.
GTO doesn't have to mean Gran Turismo Omologata either. Many acronyms have multiple uses and translations, no one any more valid than the other.
And that's my point, the rest is talking in circles...
Let's not even open the hornet's nest of what a "true fastback" is... It's an endless argument with no beginning or end or point.
Or what "4x4" stands for, as opposed to what it's been applied to over the decades...
Bottom-line, I'd bet the fellows who made the decision and designed the emblems to be put on the Mustangs were very much insinuating the convertible rear seat.
You can probably make a valid argument that "2+2" was benchmarked earlier, and had nothing to do with a folding seat. But that doesn't mean that the 2+2 on the fender of a 1965 Mustang isn't denoting that folding seat feature. You'd be overthrowing the thoughts of the people at Ford responsible.
#30 · (Edited)
Maybe you're lost, but I'm still here :)
If the Pontiac GTO were GTO then it would be GTO whether it were called/badged the GTO or not. ;)
I won't run through the details again unless you'd like me to clarify.
But, in a nut shell, there seems to be an argument that the fastback is a 2+2 "for some reason that Ford states" but that reason doesn't really matter because whether Ford stated it or not, the fastback would be a 2+2.
It's not a badge that makes it a 2+2.
It's not the sport deck.
It's the seating configuration. 2 in the front. 2 in the rear.
#31 ·
Well, this has been a really interesting discussion of how many angels could dance on the head of a pin.
You wanna drive people crazy, tell them the only Mustang "fastback" was the 67-68, and 71-73.
#40 ·
Apparently ;)
This thread was to clear up what 2+2 means and then identify where the Mustang fastback overlaps with the general meaning. When I said that "2+2 has nothing to do with the sport deck" it is to say that the folding sport deck has no impact into whether or not a vehicle is a 2+2.
"2+2" does not mean "folding rear seats."
Perhaps marketing decided to specifically call out that the fastback was a 2+2 to draw attention to the sport deck (because nearly all 2+2s are only officially called 2+2s when there is a 2 seat version already available....I explained all of this in my initial post) but while considering this, it's important to note that the fastback is a 2+2 under the technical sense of the term and the colloquial sense of the term without taking the sport deck into consideration at all. The one area that it is inconsistent with is common marketing usage because of reasons already stated.
Also, keep in mind that even under the assumption that "it has to do with the rear seat" that the folding sport deck was an option in 1967 and 1968 yet the vehicle received no "2+2" badge to indicate that this option had anything to do with their marking. If they had marked one with a sport deck as "2+2" it would lend credence to your interpretation of its meaning, at least to Ford's usage with the Mustang. But they didn't and that does not go to say that you are wrong as to Ford's meaning, but that the lack of a "2+2" badge should not be taken to mean anything at all. They removed the badge with a style redesign. It's as simple as that regarding the badging.
#41 ·
I think if one were truly able to trace the origins of the term "2+2" all the way back to its first applications to vehicles with 4-wheels, and followed it back forward, you'd find... A big fat mess.
Which is precisely why I don't get too obsessed with semantics in the automotive realm. It's nothing like, say, human anatomy or chemistry...
Terms are applied to automobiles, historically, with heavy doses of poetic license...
#45 ·
This whole discussion seams like MCA on steroids!
Stan
