leafsprings
3.6K views 34 replies 18 participants last post by  Idaho Stanger
Does anybody have a trick to get the front bolt out. The frame is in good condition so I don't want to cut it or torch it. It spins and the nut is off. Tried to put nut back on and hit it with drift pin but the angle makes it very difficult. It is also soaked in penetrating oil.
I had the same issue, angle grinder with cut off wheel or sawzall and lots of blades. Just cut both ends of the bolt between the mounts of the frame (cut through the rubber ends of the springs). I will stink up the garage a little but about 15 minutes per side...common issue.
Did the same thing to my car this week. I put an impact wrench on the bolt and spun it. That broke it free. This car is pretty rust free so it was easy. The car before this was a different story. My garage stunk of burning rubber for three days!
Go to a Midas, CarX or other place that replaces leaf springs. A minute with the cutting torch and a spring is off. The car is up on a lift with fire extinguisher right in each stall.
Last time I replaced leaf springs (my Wisconsin 70 Torino rust bucket) I used my cutting torch and gave it heck! Don't do it! I was single at the time, alone at my house, could have burned the house down!
#35 ·
Good story Slim!
+1 Sawzall
Finesse (c-clamp and a socket, and or rotate the frozen bolt/eyelet with a ratchett and use a hammer push to one side as much as you can, or pry bar, or with the aft leaf spring free from the shackle, leverge the leaf spring to one side, and or any way you can think of) the leaf spring within the perch to give you access (limited) to the bolt shaft (not the metal sleeve that the bolt is frozen into) and use the sawzall to cut through the bolt only and bam, less than 5 minutes later, for me, with only using 1 sawzall blade, the son-of-a-gun was out!
Does anybody have a trick to get the front bolt out...
I paid a pro to do it. :shrug:
Not much choice for me... I don't have a torch or sawzall or power chisel or pickle fork or any of the tools (or skills) that might remove a bolt that's rusted in place.
IIRC, my local shop charged for 2-3 hours to R&R the leaf springs (I supplied the parts).
Related thread:
http://forums.vintage-mustang.com/v...om/vintage-mustang-forum/663786-passenger-side-leaf-spring-removal-success.html
I wouldn't do this job with a torch if you held a gun on me. I'm pretty good with a torch, but I have seen way too many examples of Mustang flambé to consider it.
If the bolt doesn't slide out, I use a hammer tip on an air hammer to pop it loose from the sleeve. If that doesn't work, I go for the cutoff wheel, cutting the spring off the eye. Then I rotate the eye 180°, and cut it again, removing the eye from the bushing. Then I cut through the bushing, to cut the sleeve and bolt in the center. The quick and safe way.
I used a cutting wheel to cut the bolt on both sides of the leaf spring.
Mine had rusted itself to the metal tube insert, and there was no amount of pounding, penetrating oil that would have gotten it out.
Well tried a c-clamp tonight no luck. Just bent the handle on the clamp. Ill try the extended nut and bolt trick. If all else fails I'll go the sawzall route. Thanks for all the help. It is the last thing I have to do before I can paint the bottom and put all the suspension back on.
#29 ·
OK, if the bolt is out, the spring should be laying on the floor. The bushings are removed and installed with a hydraulic press. Are you planning to replace the bushings and re-install the old springs? Unusual.
#28 ·
Im stalled on my project until the weekend. Never replaced those brushings. I would take the spring outside and torch the brushing until you can push it out. Probably just heat the spring until the rubber is soft. I don't know if the new brushing has to be pressed in.
#31 ·
Oh. I have seen them stick in there. Not actually attached deliberately, but years of being there can cause that. It's two pieces, like the one in the spring, just shove something in the hole, try for the gap in the center, and pry.
#33 ·
i finally got it out with one of the short stubby flat heads, about 3" long including handle. Nothing else would fit.
The front's were actually really easy. Took about 5 minutes per side. What I did was put a hefty end wrench on the outside (nut side) and put nothing on the back side (bolt side). I held the wrench firm then bumped it about 5 times with a 3lb sledge hammer. That broke the back side free. Then I was able to put a wrench on the backside to hold the bolt still while I took the nut off. Bolts slid right out.
