To recap my struggles with the FiTech EFI have been ongoing since I installed the unit. Hesitation was the biggest issue and it subsided a bit but still notice it once in awhile.
My last issue I had was after driving the car for awhile, the RPM would stay high in the 1300-1500 range. The stall converter would mask it while I drive until I would put into park and notice it's idling high. Also I had an issue leaving work the last time I drove the Mustang to work and came out and the engine wouldn't turn over. Tried a couple times but would just crank but wouldn't turn over so I checked the hand held and it would not come on. Had this issue few months back when one of the prong in the 6 prong socket had overheated and melted the female receptor. Got it cleaned up to drive home and FiTech sent out a new 6 prong female receptor. Worked fine until last incident at work. I took it apart and it was fine, checked the fuses and they were fine. So put everything back and went back in the car to check and the handheld was back on. Engine turned over and I drove home.
Anyways, didn't have a chance to drive her for over a week due to rain and cloudy conditions. Today was nice a sunny so I decided to take her for a drive. Went to turn on the engine and nothing, not even cranking so i figure the battery was low and I've been waiting to replace the battery with a new one, took that opportunity to replace the battery. After replacing the battery, noticed the handheld was off again. It was on before I replaced the battery so back to checking the 6 pin connector and fuses. Everything still looked fine but I cleaned the prongs anyways and the handheld came back on. Engine started up but didn't seem to idle high enough. Got the engine up to temp while I tried to adjust the throttle adjustment screws. Got the RPM up but the IAC was a 0 so I turned the engine off to plug up all the vacuum ports to check for vacuum leaks. Wasn't able to get the IAC up even with all the ports plugged so I started putting everything back the way it was and then the engine died. The handheld I was looking at to do the adjustment went dark and then rebooted itself. Started the engine up again and started to put my tools away and same thing happened, screen went dark and engine shuts down and screen reboot itself. Happened once more after that. I made sure the connectors were seated tightly and not moving around. At this point, I gave up and drove my daily.
Going to call FiTech tomorrow to see if they have any idea what could be causing this. These ongoing issues are bringing be closer and closer to the Summit 600 carb. The FiTech have been a lot more trouble than it's worth for me. Maybe I just got a lemon.
